went to a pull in lennox sd
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: went to a pull in lennox sd
    Posted: 04 Aug 2013 at 4:58pm
got a third, fourth and a second to last in 3500 4000 and 4500, hard grippy track too much traction for a stock wd to spin out on, deceivingly grippy, rode a wheely the entire way after 30 foot or so... that was fun, well weighted, didn't need to use the brakes to steer. had the throttle all the way up, so idling basically and spun out in 3500 and the announcer said I "ran out of oats", had a good laugh about that... also developed a slight radiator leak
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 4:59pm
also gentlemen, lets keep this thread from turning in to the hodge podge the other thread got turned into
volfan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote volfan Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 5:12pm
congrats . Its shouldn't be a hodge podge this time after all you didn't call anyone out in this post like done in last post.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 5:20pm
You live near Lennox? From '70 to '78 I lived at Marion!
Greg Kroeker
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2013 at 7:58pm
Try airing your tires up on a hard track if you need a little slip. ...do the opposite for the opposite effect. Sounds like you had fun.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2013 at 1:22pm
no i live 50 miles away from sioux falls so it was a bit of a drive
