Diesel Rocker arm Stands
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Topic: Diesel Rocker arm Stands
    Posted: 20 Mar 2013 at 9:18am
e
Edited by O.P.S. Heads - 21 May 2015 at 10:45pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 7:43pm
Originally posted by O.P.S. Heads O.P.S. Heads wrote:
If anyone has a set of the "older" 301 or 426 diesel rocker arm stands that use the longer 3/8 bolt I would be interested in at least one complete set if not two. The newer ones use a short (like 1 1/2 long) 3/8 bolt and the older ones are much longer with the bolt boss being the same height as the other 9/16 retaining bolt / head bolt.
If anyone has some of these PM me or send an email to opsheads@hotmail.com.
Thanks
Steve, I'm pretty sure I have a couple rocker shaft assemblies with the taller stand. I don't think I've ever seen one with a step for the shorter 3/8" bolt. Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2013 at 8:30pm
e
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2013 at 7:17am
All 426 were the same height for both bolts all 301 had the long and short bolt. I should have some if you still need some.  MACK
This page was generated in 0.118 seconds.
