confirmed allis hd9b
diesel smoke76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote diesel smoke76 Quote  Post ReplyReply Direct Link To This Post Topic: confirmed allis hd9b
    Posted: 09 Mar 2013 at 4:10pm
I looked at the hd I asked about a few days ago it is hd9b for sure. Pads rails pins and bushings are near 100%. Also very nice weld on drive sprocket. Also has Garwood blade. Went ahead on the deal.   Question is book says 9 ton crawler without blade,belly pan or winch. Does anyone know what blade would weigh? Im thinking 2000? Thank you Matt
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2013 at 9:09am
I would say at least 2000 lbs, but am just guessing. Can you post some pictures of this beast when you get a chance? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote diesel smoke76 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2013 at 6:12pm
I will post pictures as soon as I can pick it up depending on a very nice man selling this for his friends estate, trucking arrangements and the weather. matt
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 1:47am
Matt, I don't have the specified weight for an HD9 blade machine but I do for an HD9G......bucket machine......ready for work it is 29920 lbs......quite the chunk of iron.
Mactractor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mactractor Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2013 at 3:17am
HD11 straight blade is 3500 lbs, angle blade nearly 4000. Early Buda powered HD11 and prolly HD9 Garwood angle blade I`m guessing would be at least 500 lbs lighter than those AC built blades
