Approx wd hp
kniesshy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kniesshy Quote  Post ReplyReply Direct Link To This Post Topic: Approx wd hp
    Posted: 09 Mar 2013 at 11:27am
Not looking for exact numbers...just approxamate...what would a wd block stroked to 5.5 and bored to 4.5 in. dyno? Would it break 100 or just below...just trying to get a feel of how much to go...b nice to have 100hp:)
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 11:29am
 ay it would depend heavily on cam, carb and RPM...100 sounds doably though...but i can't wait to here what the experts say!
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 3:29pm
350 inches depends on build but 100 is possible
Post Options Post Options   Thanks (0) Thanks(0)   Quote kniesshy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 7:02pm
thnks! So 100 is pushin it?
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2013 at 9:48am
a 320 cid can make over 100. It takes a good head and related parts from someone who knows what they're doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2013 at 10:02am
I think it would be wise to consider the RPM that you can make the 100 HP at. To achieve 100 PTO HP at 1400 engine RPM is considerably more difficult than at 2,000 engine RPM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2013 at 12:27pm
Coronett has some at 350 inches that i have never seen on the dyno but the one i am thinking of pulled like it would at least when it was on the bottle like marty wc is pictured.nitrous pills come rated in hp
They are alot to be said by a person who decides to use crankshaft stroke to help the breathing of a cylinder head that has a real effecient exhaust port by its design . hint
Edited by mlpankey - 10 Mar 2013 at 1:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2013 at 4:08pm
Mitch, do you talk with your mouth full too. Every time I read your posts, I read it 2 or 3 times and hear the same thing. Homer Simpson with his mouth full. Try and type one complete sentence at a time expressing what you have in mind, if at all possible. Just a thoughtWacko
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2013 at 8:17pm
Har,har!
