Aluminum frame rails wd/ wd-45
firephight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firephight Quote  Post ReplyReply Direct Link To This Post Topic: Aluminum frame rails wd/ wd-45
    Posted: 14 Feb 2013 at 8:12pm
wanting to make a set. looking for some pics and strucure advice
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2013 at 10:04pm
Be sure your local rules will alow that before spending the $$$$.
WildBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2013 at 10:02am
I all argument on this forum if tractor pulling had rules like NHRA drag racing things would be easier. It's amazing how many different rules there are! Up here aluminum rails are ok. But if u go to a Natpa event . Not possible. Where I'm from there is 4 sleds in 200 miles and each of them have different rules ? Alot of studying !
Allis fan for life !   B,C,2-WC'S,WD45G,D19G,190xt ,LLSS 8010, terra tiger refurbished
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2013 at 10:14am
The late Kerry Hensley ran one with aluminum frame rails had it down to 3000lbs
Post Options Post Options   Thanks (0) Thanks(0)   Quote WildBill Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2013 at 10:58am
What was it on Pank ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2013 at 8:20pm
Wd 45 along with the aluminum frame rails it had a hydraulic clutch and a 392 cubic inch motor from Barney pulled 3 rd and 2 gear in tbe unlimited rpm classes.the rails were just like stock only aluminum with aluminum bar stock welded to the end and drilled to attach to the rearend.
Edited by mlpankey - 15 Feb 2013 at 8:34pm
