Wc vs wd45
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: Wc vs wd45
    Posted: 10 Feb 2013 at 8:10pm
I was wondering which tractor would make for a more competitive tractor if they had the same tires and engine. The wc would be able to be made lighter 120 NF. The would have lower gears. I already have the NF wd45 but was thinking of changing
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2013 at 8:27pm
Low gear on a WC is a faster ratio than any WD45 low gear. Second gear in WC is still a bit faster than a WD45. WC engine RPM's are slower than a WD45 if rules put limits on engine speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2013 at 8:45pm
Ok would that mean that the wc wouldn't pull aswell in the heavier classes is all other variables are the same including engines
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2013 at 6:39am
More HP solves that little problem !!!
