D17 pistons & sleeves fit WC?
co2tom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote co2tom Quote  Post ReplyReply Direct Link To This Post Topic: D17 pistons & sleeves fit WC?
    Posted: 31 Dec 2012 at 1:57pm
I have been told that I can put WD45 pistons & sleeves in my WC & I have read on here that D17 pistons & sleeves will fit in a WD45. So...my question is can I put the D17 stuff in my WC? Will modifications be necessary? I already plan on putting a WD45 crank in it if that makes any difference. What is the cheapest or best place to get parts? Thanks.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2012 at 3:00pm
pistons yes, difference being compression ratio. sleeves may be slightly different im not sure but i think they are the same  but bearings and seal kits will be different than wd45
im sure the vendors that advertise on the sight would be happy to piece together a parts kit for you
Edited by CAL(KS) - 31 Dec 2012 at 4:40pm
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2013 at 9:22pm
You CAN use WD, WD45, D17, 170, or 175 sleeves and pistons in your WC with WD45 crank...Either 4" or 4.125" variety. Kip
This page was generated in 0.054 seconds.
