Pump, Inj, Clutch
Bob C IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Topic: Pump, Inj, Clutch
    Posted: 30 Nov 2012 at 5:06pm
To be political correct this should go in classifieds but its pullin parts.... FOR SALE..  Dm4631 pump, same as n6, or 7580, 320 cc and 4 x 18 injectors. Hayes 10-130 steel flywheel with allis adapter, 2 disc clutch, Ram pressure plate w floater. 3 blocks, 2 locked up 1 with major ventalation problem. 1 good head and some extra parts.   Bob Clark  zero61@frontier.com  or 217 712 0984   (I could use some cummins parts)
kidwell137nfd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kidwell137nfd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2013 at 9:58am
What size is the flywheel and clutch setup?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2013 at 10:29am
Chevy 10-130 hays flywheel and 10 inch disc ram pressure plate
ACFarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACFarmer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2013 at 1:48pm
How much on the pump and injectors, and what kind of power did you make with them?
Making a living farming with and working on Allis Equipment
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2013 at 2:07pm
those are gone to peterson. was a pretty hot DM4.
SabrinaRojas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SabrinaRojas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2013 at 7:48pm
Wow, sounds good
"I love sexy lingerie and feminine things. It makes me feel nice to look good and turn somebody on by doing so. " ~ Lorri Bagley
Post Options Post Options   Thanks (0) Thanks(0)   Quote kidwell137nfd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2013 at 7:53pm
Do you know if the clutch and flywheel will fit a 200 rearend? I am putting a 426 in a 200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2013 at 8:12pm
flywheel is for a 301
Post Options Post Options   Thanks (0) Thanks(0)   Quote kidwell137nfd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2013 at 8:23pm
How much for flywheel and clutch set up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob C IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2013 at 6:46am
1000 dollar bill
