Gearing down Wd45? |
Toddm
Topic: Gearing down Wd45?Posted: 28 Oct 2012 at 1:08pm |
Started pulling this year and learned alot. We have a Wd45 with a d17 motor in it. We have more power than what we can put down now. We can slow it down to idle and still spin out. so we want to gear down this wd 45 to run 15/5/38 and keep ground speed the same or slower than 16/9/28. Needs to say at or under 3mph for the speed limit. Thanks
cwhit
Joined: 12 Sep 2009 Location: Sigel IL Points: 1035 |
Posted: 28 Oct 2012 at 1:46pm |
Toddm, we're in the same boat with ours. We've come up with a 45 diesel rear end that should slow downthe mph but I have'nt researched just how much slower. It will be a winter project. Hopefully someone will post some info on this.
Fields
Joined: 25 Apr 2011 Location: Reedsburg, Wi Points: 359 |
Posted: 28 Oct 2012 at 4:32pm |
I run a wd45 diesel rear end and 15.5-38 tires. at stock rpms I'm 3 mph or less pulling.
graveyard
Posted: 28 Oct 2012 at 6:26pm |
if you research older posts, that may help. Getting ready to change ring and pinion on my 45 with a d 17 series 1 tractor.
