How to "Setup For Pull" 101
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Topic: How to "Setup For Pull" 101
    Posted: 21 Aug 2012 at 8:50am
OK, now can I see some pulling secrets on here- other than give it hell, as long as you keep going, you're still in.- from, the give it hell, as long as you keep going you won't get stuck!
Edited by JoeO(CMO) - 21 Aug 2012 at 8:52am
IL-D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 9:48pm
3 things to remember to make a good pull.... 1) traction, 2) power, and 3) traction LOL
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:02am
Traction is my issue! My 16.9x28's just won't dig in a grab the track. I dropped down to 5 psi but the tires still don't ripple or dig in.
Charlie
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:29am
What for tires are you running? What tread type?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:55am
Not sure what brand they are. Hitches, we have to use stock with twisted clevis most pulls. Some places allow custom hitches but I don't have one.
Charlie
cotncrzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:57am
  Charlie,
   I was having the same trouble. I have a set of 16.9x26 off a combine on my WD. They didn't want to bite in the track. I fixed them by sharpening them. Just find some concrete tie the tractor to something solid, put in reverse and let them spin slowly. I used bleach to soften the rubber and water to keep cool, it takes a while but will give a nice edge.  They look like Firestone 151's, a pullers dream!
Edited by cotncrzy - 22 Aug 2012 at 6:59am
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 6:58am
Could I bolt a "D" ring to the draw bar support and remove the drawbar? Or is the support/casting not strong enough for it?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote cotncrzy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 7:14am
  I have saw it done, make sure you are at maximum height allowed. Most places I have been allow 20" for pure, and modified farm stock. Remember, lower tire pressure allows for squat, which reduces hitch height, which "unloads" the tires. I am far from a pro, we keep notes on track conditions, tire pressure, etc... On tight tracks, in 3500# class I have dropped my hitch to keep the front end down andoff the wheelie bars. 1" on hitch makes for several feet on the track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IL-D17 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 7:28pm
those tires that you show pictured would make for excellent pullin tires!!! Need to shorten up drawbar as short as rules allow ( 18" from center of rear axle to hook point here) and raise it as high as rules allow ( 18"-20" here depending on class). also do as said and anchor tractor and spin in reverse on concrete. know a guy that dun that and it works! be patient, tires will get hot and need to let cool down then do again. Dont know the air pressure you run but air them down so tread is flat on ground before spinning backwards.
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 8:13pm
Charlie, find another drawbar and shorten it up. ( Don't do it to your org. hitch ) The pin hole will be right behind the botton support. Should keep you at 18" from axle and still look "stock". Then get some flat plates to put under the drawbar to get your height up. That should make it pull down on that 17. Also keep your tire pressure up to around  12lbs. Just because your tire doesn't flex on the outside doesn't mean its not cupping inthe center . After you pull look in the tire holes on the track.  If its shaped like a U, let out some air. If there's dirt in the center ( cupped) add air.
KevinC(MD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinC(MD) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 5:28am
Be careful with tire pressure being too low - if track is hard, keep your tires hard but flat on track.  If loose/soft, some ripple wont hurt but low pressure can upset your critical drawbar height under full power/load.  - Just my two cents...I like the ideas about sharpening!  I think this page is great too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:27am
Thanks for the hints!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 9:07pm
Shortening up the drawbar helps a bunch.   When I first starting pulling my WD45 diesel, a friend who is also an AC guy Bob Thomas gave me the same advice.   I took my two piece drawbar apart and used the front half and that helped a bunch.   The next week I made a new drawbar that was as short as I could go still using the stock cradle.   I placed 4th at the next pull.   That was one of the first things I did to my D19 was cut the old drawbar down.   It was bent from years of use and really worn on the end anyways.   So I shortened it up, and the second pull I took second.
colroy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:37pm
i agree with cwhit i have always ran 6lbs of air. this year i had a guy to explain to me when your tires rinkle on the outside the inside could be folding in not giving you enough traction. i went to 10 lbs and not bragging i trophyed everytime i pulled my 37 wc.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2012 at 8:59pm
short fat tires don't dig in well no matter the air pressure.  you should always look at your holes you  spun . the hole should be flat in bottom cupped to much air  w shape not enough air.
Edited by mlpankey - 08 Sep 2012 at 9:01pm
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 9:27pm
We could never get the D17 to pull very good with 16.9x28s on it. Changed to 13.6x38 and what a difference. I have finally found a real nice set of 15.5x38 that are about 30%. Hope to show the red tractors whose boss next year.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 11:22am
It really depends on the weight of the tractor and tire type.
I have put the one video of my C way to many times but I pulled at 6 pounds in the video. That was where I pulled it and any of my B's. I did change air pressure up from 6 pounds some but never over 8 pounds.  At the end of the video It showed me starting out with the Oliver 77 and it would have been close to 10 pounds. I pulled the 77 as low as 8 pounds. When I loaded the Oliver 88 I pulled between 10 and 12 pounds with it.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 2:09pm
 I have run 18.4X26 on a D17 and had sucess for exactly the reverse of your opinion. Short fat tires can work . I want traction , I don't want to be diggen no friggin holes.... The whole point of point of pulling is distance, right mitch?   Go forward not down and you'll be a better puller.   If tall narrow tires were the ticket, hot farms and beyond classes would be on pizza cutter looking tires?
Edited by Gary in da UP - 11 Sep 2012 at 10:20pm
Orange1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange1 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 7:44pm
The point of taller tires is you have more tire on the track from the front to the rear of the tire (length) which is more than inside of tire to outside (width)
