HD6G brake rod boots
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: HD6G brake rod boots
    Posted: 23 Nov 2009 at 2:35pm
Anyone know a source for the rubber brake arm boots for HD6G. Mine got wore out, mice got into the brake disk compartment and what a mess (disks welded together). Never want to have to redo again what I just redone. Thanks
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 3:32pm
I should still have some boots brake operating rod for HD6
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 6:43pm
i had the same thing happen to a hd5g loader. the mice will chew through the rubber. my solution which i am still working on is to make plates to cover the holes and hold a small round wire brush like you use for cleaning copper fittings for the rod to pass through. it is only in idea stage but i do not want mice in my clutches again. also, make sure the holes in the bottom of the clutch housing have big cotterpins of something in them so mice cannot get in there either. i will post pics once i have made them. it may be awhile though.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2009 at 10:55pm
"dads" -- I had the same mice problem on my HD5G -- what a mess.  I'm considering making some covers from 1/2" thick rubber conveyor belt and just sliding them up against the housing each time I finish using the machine.  Will depend on friction between the piece of belt and the rod to hold the cover in place. (may come up with a way to fasten them to the outside of the housing, but for now -- dunno).  Regarding the drain plugs, I'm going to get some pipe plugs and drill a small hole in each one to allow drainage (probably a 3/16' or 1/4" hole) -- hopefully that will keep mice out.
P.S. while I had the steering clutches out this summer, during hot weather, went out to work on it one day and a big blacksnake was cooling himself in the bottom of one of the clutch chambers.  I found 3 snake skins near the end of the loader arms over the summer.  Non poisonous snake are my friends.........they eat mice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2009 at 4:20am
i thought about taking plates and sliding them in the brake shaft with a small extension spring and a clamp to hold the plate up against the housing. that way, should you park it with the brakes locked for a short time, the plate would still be up against the housing. i like steel plates as mice cannot chew steel unless they learn to use my torch. those pesky buggers seem to get in the tightest places and will chew on anything.
ps. i had to cut my drum in pieces to get the clutch out as the plates were rusted fast to the drum and would not allow the clutch to slide in like it should to get it out. what a waste.
This page was generated in 0.087 seconds.
