D17 Series IV Steering Control Valve Input Seal
conquest87tsi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote conquest87tsi Quote  Post ReplyReply Direct Link To This Post Topic: D17 Series IV Steering Control Valve Input Seal
    Posted: 3 hours 21 minutes ago at 10:13am
I am in the middle of replacing the steering U-joints on my D17 Series IV. In the process, I realized that my primary steering system leak is coming from the Steering Control Valve Input Shaft Seal, item 3 in the diagram below. My manual says to overhaul the steering control valve, the front support needs to be removed. Can I replace this seal without completely overhauling the entire steering valve? The input shaft has "splines" on it that it appears would damage the seal on installation. I'm not sure why this part of the shaft is splined, since the force is transferred through the coupler via the roll pin.
Edited by conquest87tsi - 3 hours 20 minutes ago at 10:14am
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 39 minutes ago at 10:55am
You can replace the seal with out taking it apart I never saw a splined shaft if it is splined put tape on splines
