D15 diesel - getting fuel to the filters
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: D15 diesel - getting fuel to the filters
    Posted: 16 hours 22 minutes ago at 7:19am
I have my series 2 diesel looking more stock than when I got it.  However, I am not able to get fuel from the tank up into the filters.  I have 1/4 tank of fuel and I have had new seals put in the hand primer, but I cannot get it to pull fuel up to the filters.  The primer was tested separately and it does work.  I do have a very small leak on the 90 coming out of the sediment bowl if that makes a difference.
Would filling the tank full make a difference?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 17 minutes ago at 7:24am
it should work at 1/4 tank, but if you look at that level compared to the filtes, the fuel level is only partialy up inside the filters.. a good test would be to fill the tank and test again... and YES.. any minor fuel leak can be a MAJOR air leak and cause loss of suction.
this is WATER instead of FUEL... but gives you a good idea of a "MINOR LEAK"...
How This Affects Flow Through a Crack
  1. Laminar Flow (Very small cracks / low pressure):
    If the leak is slow and orderly, the flow rate is governed entirely by dynamic viscosity. Because water's dynamic viscosity is roughly 55 times greater than air's, air will leak out roughly 55 times faster than water under the exact same crack dimensions and pressure difference.
Edited by steve(ill) - 16 hours 12 minutes ago at 7:29am
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 40 minutes ago at 10:01am
If the tank was full, you could gravity bleed it and throw the primer away. Thats just me.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 21 minutes ago at 11:20am
Fix the leak for starters.  Adding more fuel to the tank will give it more head pressure and it will leak more.  A leak on the suction side of any pump is not a good thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 37 minutes ago at 3:04pm
is that a factory setup with the primer pump stick out the top of the filter , way up in the air ?.... would have been a better design to have an elbow on top of the filter and put the primer at the side of the filter, or below.......... but fixing the LEAKING ELBOW might fix all your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 12 minutes ago at 3:29pm
That's how a series is 2 is supposed to be set up - wasn't like that when I bought the tractor.
Some have said it is not the greatest set up with the primer that high up, but given the space constraints around the sediment bowl, that's where it sits.
I will top off the tank and fix the leak and it should be good.
Thanks for the responses.
