D 12 front oil seal
54f250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 54f250 Quote  Post ReplyReply Direct Link To This Post Topic: D 12 front oil seal
    Posted: 2 hours 14 minutes ago at 7:28pm
I am replacing the front main oil seal on my D 12. I have removed the radiator, pulley, etc to access the crankshaft.  My question is, do I need to remove the timing cover or do I simply pull the seal and replace it? I have read the manuals but I am still unclear.
Thanks, Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 2 hours 10 minutes ago at 7:32pm
i have done a couple "B" tractors ( similar)... and i remove the cover to make it easier to get the seal out.. Also inspect the shaft to see if it is grooved.. Excess wear can cause a leak and they make a thin sleeve to cover the journal if needed..
