CA Valve Spring Specs |
dfwallis
Joined: 09 Mar 2023 Location: Texas / Indiana Points: 1054 |
Topic: CA Valve Spring SpecsPosted: 2 hours 11 minutes ago at 1:11pm |
Ive finally gotten around to diagnosing the misfire issue. Im measuring valve spring tension and none seem to be as expected. The stongest one is 55psi and one was only 35psi. The head rebuild was supposed to take care of that. Ill measure again after i research my technique...i bought an on head tool. It seems easy enough to use. I & T says 55-65psi to 1 5/16". One source says 70 psi but none approach that.
Edited by dfwallis - 1 hour 23 minutes ago at 1:59pm |
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
