D17 head gasket leak |
Putnamd17
Topic: D17 head gasket leakPosted: 18 hours 35 minutes ago at 6:24am |
After rebuilding the engine and having the head redone, it was cut flat and the whole works, I tightened Down the head in the order in the book and when I was adding coolant I was getting a pretty good leak along the entire side of the manifold, I got the rebuild kit from reliance, did I do something wrong in the rebuild or are there common issues with those gaskets? I have another head gasket that is metal instead of the composite, would this be better?
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4454 |
Posted: 18 hours 31 minutes ago at 6:28am |
Did you coat the gasket with anything like coppercoat?
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3184 |
Posted: 18 hours 27 minutes ago at 6:32am |
You had the head milled flat but how is the block deck and sleeve standout?
Putnamd17
Posted: 18 hours 25 minutes ago at 6:34am |
Sleeve standout measured within tolerance of what the book states, I didn’t use any sealer with the composite gasket I have some of the copper sealer that comes in a spray can
A-C_220
Posted: 18 hours 24 minutes ago at 6:35am |
Are you sure it's the head gasket, or could it be coming out of a manifold stud?
DrAllis
Posted: 18 hours 9 minutes ago at 6:50am |
Those gaskets (of any type) MUST be coated with something or they will leak. Some may argue about this, but after 50+ years of never ever having to redo a leaker, I think I'm right. Run a thread tap down every head bolt hole and blow out the rust/dirt. Wire brush off the head bolt threads clean and wipe some grease on the threads. Re-torque head bolt COLD after 2 to 4 hrs of run time.
Putnamd17
Posted: 18 hours 7 minutes ago at 6:52am |
Ok thank you, which head gasket would you use and which sealant?
DrAllis
Posted: 17 hours 60 minutes ago at 6:59am |
I use a product called "Hylomar" sealer around the outside and around every water jacket and oil passage hole on both sides of the gasket. Copper Coat should be OK fine. Just paint it at least one good coat and then a second coat and assemble while tacky. I don't care which type of gasket. They all will work AND seep coolant if not coated with something. I might even reuse the gasket you have but I'm not there looking at it either. Wipe and air dry the block and head with brake kleen on a rag to be clean. Just be sure to not use so much sealer it could plug any small coolant passage holes.
Edited by DrAllis - 8 hours 3 minutes ago at 4:56pm |
Allis dave
Posted: 16 hours 43 minutes ago at 8:16am |
I rebuild my WD45 10 years ago. I followed Doc's advice and put a thin coat of sealer around each jacket in the head. So far no leaks.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4253 |
Posted: 15 hours 33 minutes ago at 9:26am |
i try reusing a new head gasket that had only been tightened down to check piston valve clearance on my d17 gas engine it had a little sealer on it, it leaked faster than you could put coolant in , put new felpro on sealer orund the holes and all was good , have reused some head gaskets before that were in bad shape in a pinch and they worked fine
