L3 Gleaner? |
SteveMaskey(MO)
Joined: 11 Sep 2009 Location: Wellsville, MO Points: 636 |
Topic: L3 Gleaner?Posted: 1 hour 58 minutes ago at 9:33pm |
Is there any way to bench test the 71313444 magnetic pickup sensor to see if it is good?
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2557 |
Posted: 1 hour 16 minutes ago at 10:15pm |
I believe that they are nothing more than just a coil of finely wound wire. It should have a specific ohm amount when checked with a meter. You can compare the reading with a known good one or even swap it to a different function to see if it works.
