Need help with drum brakes |
modirt
Joined: 18 Jul 2018 Location: Missouri Points: 9991 |
Topic: Need help with drum brakesPosted: 2 hours 29 minutes ago at 9:30am |
So backed the hay monster out of the barn the other day, and as it started moving, heard a big BANG out of the back axle. Got it moved where it needed to be, then found rear axle locked up. Jacked it up and what we found was left rear tires were locked up. Once we pulled it all apart, what we found was a broken retractor spring on the brake drum pads. No worries, we just get a spring kit. Not so fast........what spring kit? Truck parts place spent half an hour looking and came to conclusion it would need a Leland K196 kit. This one........ ![]() Except the springs in place, and busted one don't match up to the picture. ![]() So in order to try to narrow this down, how does one go about knowing what axle, what brakes and brake drum kit I actually need? Are there any ID numbers to be found anywhere? Believe hay monster was built on a Dodge D600 truck chassis, circa 1970, but that is a ballpark year only. Also believe rear axle is same one it left factory with, but no way of knowing for certain.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36679 |
Posted: 2 hours 22 minutes ago at 9:37am |
Will be an Eaton, only Two with that series Axle Shaft and only One with Hydraulic Brakes.
DMiller
Posted: 2 hours 21 minutes ago at 9:38am |
Two Cylinders per wheel, that series Bendix has LONG been Obsolete.
modirt
Posted: 1 hour 53 minutes ago at 10:06am |
I may need an interpreter......as this was my first ever look inside a set of drum brakes like this.....but guys at truck parts place also said it was ALL obsolete and not available......except some of them ARE available on ebay. But you need to know what it is you are looking at, to figure out which kit you need. On the Leland kit, there are at least two other "similars" on ebay.......but really none of them look the same as what I'm seeing in this picture. But if you can ID the thing for certain, there are places with NOS to sell. Or .........last ditch would be off to a salvage yard to find a truck being parted out. Problem with that is the springs you could get from there may not be much better than what I have now.
DMiller
Posted: 48 minutes ago at 11:11am |
Need to look thru 2-5ton truck brakes catalogs, will be a hit and miss to locating Similar or Close but none will be same. Some parts stores as the Carquest I work with here still have Older Paper BOUND catalogs where Could be any manufacturer still using a Similar setup.
May still come up empty handed. |
DMiller
Posted: 33 minutes ago at 11:26am |
Major manufacturers for the Big Four GM DODGE FORD and IH were all similar Bendix Wagner Midland.
Midland was absorbed into Bendix, Wagner continues until closed completely, all are now under Meritor. 90+% of All medium duty Drum brakes are as our Allis machines NOS someone is sitting on or gone. |
