‘Nother Water Question |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12513 |
Topic: ‘Nother Water QuestionPosted: 08 Oct 2026 at 7:07pm |
Soooo… it’s recommended that the air pressure in the bladder tank be set 2-3 psi lower than cut on pressure.
Water at dad’s was acting up. Biggest problem turned out to be the sense line to the switch was plugged. Anyway for thoroughness I replaced the pressure switch. Guess I bought a lower pressure setting. I bought a 30-50. When the switch kicks on bladder tank pressure is about 35. It seems to be working fine and cycling normally with a steady flow of water. So, ??? Should I put a 40-60 on it? It doesn’t seem to be broke so I tend to not wanna fix it! Got plenty of other things to do.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 927 |
Posted: Yesterday at 12:21am |
My Daddy taught me the hard way if it aint broke dont fix it
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5319 |
Posted: Yesterday at 6:06am |
Sometimes it creates a problem where there wasn't one before.
plummerscarin
Posted: 20 hours 55 minutes ago at 11:55am |
If you’re happy with the pressure and flow leave it alone
