WD Governor
bleedingorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleedingorange Quote  Post ReplyReply Direct Link To This Post Topic: WD Governor
    Posted: 02 Oct 2026 at 1:28pm
Tractor was running and plowing fine. Governor was working fine. Than it just quit. Runs a lil over idle. Governor weights and linkages are fine. Spring isnt broke. Sheared pins is all i can think of. Its out of warranty! Lol
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2026 at 2:27pm
While I can’t answer your question, the warranty comment made me laugh. 6 or 7 years ago my uncle was mad there was no warranty coverage when the rear spindle snapped off the M3
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2026 at 3:49pm
normally the governor problem causes a RUN A WAY speed.... If its stuck at idle, i would look at the throttle to governor arm, to cross rod, to carburetor linkage and see what is STUCK or fell apart.. ... Push the throttle arm FULL FORWARD, then look at the arm on the carburetor... it should be a full stroke away from the STOP screw..
if the carburetor rod is FULL STROKE, then the throttle plate fell off in the carburetor, or the choke plate fell off or the main jet is 90% plugged.... etc.
Edited by steve(ill) - 02 Oct 2026 at 3:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2026 at 9:28pm
Been there. My 45 just went to idle. Sheared pin in governor cross shaft inside gov hsg. Was able to remove front gov cover and replace pin in the field,
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleedingorange Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 3:53am
The pin that goes thru the fork and shaft?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 8:46am
I believe that's correct. That was 40yrs ago.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2026 at 1:08pm
Sorry I cannot help. But your warranty comment helped my day.
