b12t power unit or RC motor?
AintCheatnAintTryn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AintCheatnAintTryn Quote  Post ReplyReply Direct Link To This Post Topic: b12t power unit or RC motor?
    Posted: 30 Sep 2026 at 6:01pm
I picked up a. motor the other day with a plate on the Bell housing that says I have a power unit, serial number PU 85262 B but the number stamped into the block beside it says RC 53517 PA.
aside from the power unit governor, is there I difference between the two?
am I getting confused by the numbers or does it sound like someone attached an RC motor to a power unit drive?
who needs practical experience when you have a computer, a calculator and ideas? me.. dumb ideas get expensive fast.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 6:23pm
i always thought the RC was a Factory Replacement for the CE engine ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AintCheatnAintTryn Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 6:43pm
perhaps, honestly I don't know much about anything other than the wc-d17.
i did however learn since posting I got mixed up on the block stamp, it's cr, not rc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2026 at 8:41pm
well... this is what GOOGLE said..
On an Allis-Chalmers engine, the CR prefix in the serial number indicates a combine-spec engine (such as for Allis-Chalmers harvesters) built on a standard 125 cubic-inch block.
Key Details
  • Higher RPM: It runs about 200 RPM faster than a standard tractor engine block.
  • Special Oil Tray: It typically features an oil tray on the valve studs for better lubrication during stationary or high-angle combine operation.
  • Interchangeability: It is fundamentally a 125 CID engine (similar to the CE blocks used in the Model B, C, and CA), which is why these combine engines are frequently found swapped into standard Allis-Chalmers tractors.
