Need a transmisdion oil cooler for 7040
jazzsuds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Topic: Need a transmisdion oil cooler for 7040
    Posted: 22 Sep 2026 at 9:18pm
Folks I need to replace the oil cooler that mounts in front of my radiator on a 7040. Any suggestions where I could get one is appreciated and the part number.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 10:15pm
Are you talking about the "second" oil cooler for the Power Shift transmission?? which was connected by tee fittings at the bottom tank of the radiator ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 6:32am
Isn’t the cooler in front of radiator for power steering
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 7:02am
Early 7040/7060 Power Shift tractors had inadequate cooling of the transmission oil. A second oil cooler was placed ahead of the radiator and teed into the existing bottom radiator tank cooler plumbing. I didn't find it under 7040, but did find it under 7060 in AGCO Parts books. The second cooler is the same p/n (70266313) as the power steering cooler. So, whichever cooler ahead of the radiator is leaking, they are both the same part.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2026 at 12:17pm
Thank you
