7040 radiator hose hookups
jazzsuds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Topic: 7040 radiator hose hookups
    Posted: 21 Sep 2026 at 10:36pm
I justbought an aluminum radiator replacement and cannot find the part numbers and size of the two fittings fir hose hookups on the engine side of the radiator. Can anyone help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 7:55am
 You don't have the two adapter fittings from your old radiator ??  I think the hose connection is 7/8" JIC 37 degree male threads and the radiator hole is either 1/2" male pipe or 3/8" male pipe.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 8:35am
By whats been said more than likely the fitting in the radiator is 1/2 female NPT. The fitting that screws into it is # 8 male JIC x 1/2 male NPT
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 8:55am
My chart says #10, but I'm guessing at the size of the hose connection fitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazzsuds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2026 at 10:43am
Thanks folks
This page was generated in 0.178 seconds.
