Allis B, C & CA Fitment |
bigstone
Topic: Allis B, C & CA FitmentPosted: 05 Sep 2026 at 7:58am |
Are the torques tubes with the starter hole on three models interchangeable? Your help would be appreciated. s
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 93280 |
Posted: 05 Sep 2026 at 8:01am |
yes.. the torque tube and engines are interchangable... Few more taped lug holes on some, but all will fit........... transmission / rear end / final drives are different on the CA.
bigstone
Posted: 05 Sep 2026 at 8:19am |
Thank you Steve.
Kip-Utah
Joined: 14 Sep 2009 Location: Southern Utah Points: 945 |
Posted: 06 Sep 2026 at 9:28pm |
Late model B torque tubes and CA torque tubes are exactly the same.
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1866 |
Posted: 07 Sep 2026 at 9:47am |
I don’t think the B has the 4 tapped mounting holes for cultivators.
john2189
Joined: 11 Sep 2009 Location: Minerva,Ohio Points: 452 |
Posted: 07 Sep 2026 at 9:53am |
I have a B torque tube in my garage with my bench grinder mounted to it. It is the right height and heavy enough that it doesn’t move.
'41 Allis B
'49 Farmall Cub |
Kip-Utah
Posted: 08 Sep 2026 at 10:11am |
I have seen several late production Bs with the CA tapped cultivator mounting holes in the torque tube.
dfwallis
Joined: 09 Mar 2023 Location: Texas / Indiana Points: 1050 |
Posted: 08 Sep 2026 at 10:38am |
The CA is about 5 inches longer than a C, is that entirely from the rear end?
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
Les Kerf
Thanks(1)
Posted: 08 Sep 2026 at 11:58am |
Yes
steve(ill)
Posted: 09 Sep 2026 at 7:58am |
the differential case has 4 bolts that hold the final drives to each side.. The finals on the B-C are completely vertical to the case... the CA has the final cases turned slightly so the finals tilt BACKWARD somewhat.. giving a longer wheel base..
The troque tubes go by DATE.. The early B and C are identical and have no mounts for the implement... When the CA replaced the C, they added 4 tapped lugs to each side to hold implements under the tractor... at that point the same torque tube was used on the B which was still in production.
Edited by steve(ill) - 09 Sep 2026 at 8:00am |
steve(ill)
Posted: 09 Sep 2026 at 8:08am |
you can see the LUGS on the side of the torque tube... and the angle of the final drive mounting.
Edited by steve(ill) - 09 Sep 2026 at 8:09am |
Les Kerf
Posted: 09 Sep 2026 at 11:34am |
I just now did a crude tape measurement of my CA and Model C transmissions, the CA 4-speed transmission is a smidge more than 1-1/2" longer than the Model C 3-speed. The majority of the length increase is from the rearward angle of the final drives.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5453 |
Thanks(1)
Posted: 09 Sep 2026 at 1:49pm |
The CA is also an inch or so longer in the front support casting as opposed to a C.
Les Kerf
Posted: 10 Sep 2026 at 8:34am |
Is this only from the increased length of the cultivator mounts protruding to the front, or does this actually increase the length of the wheelbase?
Kip-Utah
Thanks(1)
Posted: 12 Sep 2026 at 5:00pm |
The bolt hole bosses coming through the radiator shroud on the CA is the only change. The front support casting is interchangeable between the C & CA if the radiator shroud is modified on the C to clear the bolt hole bosses.
