7060 cowling sealing |
whatscooking
Topic: 7060 cowling sealingPosted: 03 Sep 2026 at 4:20pm |
Went looking and found what foam was in there was a crumbling mess, nothing stopping the heat. It needs a firewall. Going to remove the bypass filter and make a barrier, going to put of some of that peel and stick sound and heat materal behind that to divert the fan blowing the heat. Its like 102 heat index here today.
68 D21 81 7060
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 93310 |
Posted: 03 Sep 2026 at 4:48pm |
some of that stuff is just FOAM and is pourous and will leak dirt / air thru it... Some of the stuff is more like caulking and no air pockets thru it......... that might be better ?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 930 |
Posted: 03 Sep 2026 at 5:43pm |
Dynamat will do the job. I dont think it will ever break down
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
whatscooking
Posted: 03 Sep 2026 at 5:47pm |
Butler Sound Deadening 80 ml, seems to be respected.
Believe i can stick it on top and fold it down behind the bypass filter bracket and curve back to the floor to block and still keep air moving down and below the cab. Edited by whatscooking - 03 Sep 2026 at 6:14pm |
68 D21 81 7060
