190 weight?
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: 190 weight?
    Posted: 31 Aug 2026 at 10:30am
Does anyone have a close estimate on what a 190 would weigh with no weights,cast centers removed and 18.4-38 9 bolt dual rims/tires put on. Hollow front bolster, late series 1 so it has the 3ΒΌ inch axles and heavy fenders, 3 point hitch on but could remove if needed. Looking to get down to 7300 pounds if possible without taking too much off just for a couple local pulls next year
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 11:13am
Nebraska Test #887 for a 190 XT (small axles) says 7750 lbs (no driver) with 18.4 x 34 cast iron centers, 7:50 x 16 fronts, SNAP-COUPLER hitch and the old fenders. I assume 2 batteries.  You can get there.  I'd try to slide the lift arms off the rock shaft and drop the draft arms. I set one up 50 yrs ago (series 3) for 7500 lbs and we had 18.4 x 38's and still used the cast iron centers with zero fluid, newer fenders, one battery and a home-made steel front support. I've done a couple and I don't think this one had the home-made NF end.
