8070 front driveshaft
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Topic: 8070 front driveshaft
    Posted: 25 Aug 2026 at 8:14pm
Slip yoke on the FWA drive shaft has a lot of play.  I assume a good driveshaft shop should be able to rebuild?
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 6:20am
Probably. I'm pretty sure those parts are all metric, and they may have that available to them after 40+ years. Seems like in the distant past some American parts have been grafted in that area for repair work when metric couldn't be had.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2026 at 12:22pm
Agco still has it, not cheap but atleast you know it should be correct
This page was generated in 0.131 seconds.
