another wd hand clutch question |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4260 |
Topic: another wd hand clutch questionPosted: 21 Aug 2026 at 9:29am |
can the wd be changed to the wd45 three disc setup if so i would start gethering parts so i can do both clutches on my wd when i get the d17d done
DrAllis
Posted: 21 Aug 2026 at 9:37am |
Parts were made to be interchanged between the two types.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5328 |
Posted: 21 Aug 2026 at 2:03pm |
My question would be, why would anyone want to change one in 2026. Every WD is at least 73 years old. It's days of being the big chore tractor are long gone. If the 2-disc lasted this long, I would suspect it will last a lot longer than any of us will.
HudCo
Posted: 21 Aug 2026 at 5:03pm |
because if i have to change it bigger is better, and i go pull it afew times a year up untill the last few years it only sliped pulling now it slips plowing shims were all gone years ago
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4469 |
Posted: 22 Aug 2026 at 6:01am |
I went through the hand-clutches on both my 45’s. Both ‘53 models, upgraded them to 3-disc. Found new and good used parts on E-bay back then. You might still be able to do that?
