Rear main seal for AC220
Meavy_Hetal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Topic: Rear main seal for AC220
    Posted: 20 Aug 2026 at 11:42am
Hi there
Will this seal http://https://www.ebay.co.uk/itm/274373696917 fit my 1969 AC 220? IT has the 3500 engine. The parts catalogue I have shows different numbers. Thanks for any help.
Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2026 at 1:02pm
Can't see it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2026 at 2:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2026 at 5:30pm
Not sure how a 220- 426 engine is , but 301,s have 2 cork like gaskets in the engine adapter plate that get hard over time and can leak- thinking you have a rear main leaking
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2026 at 7:40pm
It's probably OK, but the newest p/n is 74062088 and they list that newer seal in the advertising. Buy that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2026 at 8:58pm
Buy from AGCO dealer and ask if you can rent/borrow the install tool. Hopefully he was Allis before.
Edited by SteveM C/IL - 20 Aug 2026 at 8:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 5:52am
Thanks for the replies. The catch is being in England I'm not sure the AGCO dealers here would be able to help much as these tractors were never sold here but it is worth a shot! I have attached some pictures anyhow.
Was thinking about the clutch, its not excessively worn but tempted to replace it or get it renewed while in there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 5:58am
That rear seal is installed BACKWARDS !! It should leak  !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Meavy_Hetal Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 6:39am
That isn't going to help then! I'm not to blame I've only had the tractor a year 😅. It came from Canada...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2026 at 8:02pm
With the rear plate off the engine, no special tool is really needed. Just use a plate large enough OD and press the seal in from the rear until it is flush with the front face of the rear engine plate. Press the wear sleeve on till flush on the flywheel using some sort of loctite to seal it to the flywheel.
