190XT Low Fluid Lost Hydraulics What to check for?
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Low Fluid Lost Hydraulics What to check for?
    Posted: 11 Aug 2026 at 9:40am
I had a loader on. When disconnecting you extend the cylinders. I didn't think anything of it. Put on my grader blade and levelled the drive way. Right as I was about to finish I lost all hydraulics, but the PD still worked.
I turned it off right away, checked everything, it was, of course, low on hydraulic fluid. Filled it and everything went back to normal and works just fine.
My question is, is there anything I should check, change, grease, verify, that I didn't damage by running low on hydraulic fluid?
 Only thing I could think of would be the pump, but I don't know if/how there's anything to check. I just want to forestall any issues with good advice after my screw up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 10:14am
Check transmission oil level. I'll bet it is overfull. Nothing hurt. Carry on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 11:05am
Thanks Doc!
Transmission was a bit overfull. Does the hydro and trans mix anywhere?
I didn't lose the power director which was interesting to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2026 at 11:13am
Yeah. They mix when the oil seal between the front and rear housing has failed. A relatively common problem on old tractors. You might have an external leak, but this is one you cannot see and the hyd oil keeps disappearing in the front and raising on the back. Make sure your hyd dipstick breather is OPEN. Remove the cotter pin and throw away the 3/8" ball inside the tube.
