HD5 rear axle seal
Dobry Den Chip View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dobry Den Chip Quote  Post ReplyReply Direct Link To This Post Topic: HD5 rear axle seal
    Posted: 22 Jul 2026 at 8:32am
I purchased new seals from general gear and am struggling to insert them with the rubber gasket staying in place.  Any suggestions?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2026 at 2:31pm
I had to contrive a contraption using a board and block of wood held up with a ratchet strap when I did the seals on my Son-in-law's HD5G several years ago. Sorry, I didn't take any pictures but with some ingenuity it isn't too hard to do.
Best wishes Smile
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2026 at 6:22pm
Gasket gets glued in, can’t remember the particular glue. Will look over the weekend for what I used. Be sure to tighten the sprocket nut super tight, I think it was 1600 ft lbs.
