1944 WC rocker arm shaft oil tube HELP
rickannable View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickannable Quote  Post ReplyReply Direct Link To This Post Topic: 1944 WC rocker arm shaft oil tube HELP
    Posted: 15 Jul 2026 at 9:09pm
Hello,
I need to re-create the oil tube that attaches the rocker arm shaft collar to the cylinder head. I'm not sure what size tube the original was but I believe the tube attaches to a 90 degree brass elbow at the shaft collar and then to a straight brass fitting at the cylinder head using copper tube and ferals perhaps? Not sure.
Also, if I'm right about the 90 degree elbow at the shaft collar.... do I need to make sure the fitting lines up with the hole in the rocker shaft as I tighten it down, or does the oil make it's way to the hole no matter where the fitting ends up?
Thank you so much in advance for any help provided!
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2026 at 3:19pm
The oil line is 3/16" brake line tubing and the fittings are 90 degree elbow and straight  1/8" NPT X 3/16" compression fittings. Rocker Arm Shaft is Click on below:
Fittings are click on below:
https://www.speedwaymotors.com/Brass-Compression-Fitting-3-16-Tube-to-1-8-NPT-90-Degree,29263.html?srsltid=AfmBOoqVmAIy6bUzO3PM0wWoZsTIukY3NDqSXG4AA-M9Sf_5Qw_HtuH6
or
https://www.discounthydraulichose.com/369-03-02.html?gad_source=1&gad_campaignid=22934621220&gbraid=0AAAAAD_gh1yJGr7B9d3qKjcce-ws0F9Ki&gclid=CjwKCAjwpefSBhBvEiwAzyEtZzmEGpNokkGcQycnEe5VqlP1DVTS-JdCN7qpMs8tARtQirE0_xtX2xoCW2YQAvD_BwE
or
https://www.ebay.com/itm/383158384439?_skw=1%2F8+NPT+X+3%2F16+Compression+90+degree+fitting&itmmeta=01KXRW18N8ZH3X191DW14GHKFF&hash=item593604f737:g:bsgAAOSwYaZdgOkN&itmprp=enc%3AAQALAAAA8GfYFPkwiKCW4ZNSs2u11xDVJLp8B7NFvgqnsGtlSrGEYto%2BqP8knEAW7fBpHZYGujhDuOO8rzQmQu9r8a7p86R9LmtkM8KtPMB2uJO6BfToRjDTYQ1T9HasT5ondhoVkG9s6QtN9rB4qxc8Jj3H97XeuFmeRMnsba395%2F5t5SgQnnkyyiUNKGa5U5YPo56xfe8sY2Y%2F658j9AreBqSo%2F8NXU6l5%2B3ROUytAaTS6%2ButjX7BHf7Jl7CPQf3yxZTtwLRsC%2BiLn92Ap%2FkNr6O%2B1rOp2zimfoN246a58cD%2BB6BoAm7CZyQDkoKeWe92sly2HkA%3D%3D%7Ctkp%3ABk9SR-qKhZzuZw
Edited by Phil48ACWC - 19 Jul 2026 at 10:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickannable Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2026 at 8:30pm
Hey Phil48ACWC.... WOW!!!
Thank you so much sir. I really appreciate it!
You rule!
