7000 red belly hydraulic pump needs primed
robkoon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robkoon Quote  Post ReplyReply Direct Link To This Post Topic: 7000 red belly hydraulic pump needs primed
    Posted: 04 Jul 2026 at 1:03am
I took the hydraulic oil cooler to a welding shop to repair a leak. After putting it back on I can't seem to get it to prime. I keep taking the cap off of the JIC fitting on top of the pump and fill it up, then try it with no luck. Any suggestions? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 8:47am
Do the same thing only on the larger (and more difficult) line and if you have to remove the pump fitting, so be it. Try to get 2 or 3 or 10 ounces of oil into the pump and try again. Throttle the engine up when it starts to 1500 RPM and turn the steering wheel back and forth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote robkoon Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2026 at 3:27am
I will try that in the morning. Thanks
This page was generated in 0.340 seconds.
