What is your most wanted parts?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: What is your most wanted parts?
    Posted: 03 Jul 2026 at 10:26pm
What is your most wanted parts that you would like to be able to buy or reproduced , on the older AC tractors? Thanks, Tracy
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 1:11am
Plow shares, traction booster gauge
Edited by Les Kerf - 04 Jul 2026 at 1:12am
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 6:02am
Another batch of Nelson mufflers. Are you listening Alex?
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 7:33am
Power steering kit for a non power steering D 15
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 8:01am
CA/late B fuel tanks... Better have some capital for tooling, ha.
CA steering shaft lever pins and/or ideally the lever shaft itself. You can only buy the ones for the B/C these days (aftermarket), I believe. I am accumulating a bunch of CA lever shafts that need to be built up with weld and turned back down, where they were wearing on the bushings probably after no lube or contamination. They also need pins. The B lever shafts are $125 everywhere online which seems reasonable but they are smaller than the CA.
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2026 at 2:17pm
On the D15 power steering. Be nice if someone machined a nose cone with a gear that a regular off the shelf pump would slip into for that purpose. Even if a guy used it as live hydraulic for something besides steering.
Edited by wade89 - 04 Jul 2026 at 2:17pm
