Hydraulic cylinder piston removal.
don k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote don k Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic cylinder piston removal.
    Posted: 02 Jul 2026 at 12:30pm
What is the secret to get the piston out of a moldboard lift cylinder AC model D grader. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2026 at 11:19am
Seems every cylinder company has their own way to determine what holds the end cap or rod seal gland to the body . Each has a simple design that defies logic .
External threads on barrel , gland held in by snap ring you can see , gland held in by hidden snap ring - or some other  mysterious method . Tyrod cylinders , threaded ends , snap rings . Should be some form after inspecting the end to figure out the secret
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2026 at 12:16pm
Some cylinders require removing the pipe fitting to expose the innards to allow removal of the hidden snap ring. I dunno about yours Confused
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2026 at 5:39pm
It seems as if there is a compotation between engineers to add something no one else has done yet. Wither it is really an  improvement or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote don k Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2026 at 8:36pm
I have removed the two internal nuts that go against the packing. As far as I can see the piston should now slide out. But it doesn't.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2026 at 9:19pm
If that piston has spanner holes and has threads toward the outer side you will have to loosen that to get it out
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2026 at 9:22pm
Just a guess. My D17 series 4 was like that untill i changed it to later style cylinders
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote don k Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2026 at 6:04am
I looked again at the service manual and the inside of the cylinder. There is nothing holding the piston except seals. I am going to chain it to something and pull on it with a hoist and see what happens.
Post Options Post Options   Thanks (1) Thanks(1)   Quote don k Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2026 at 2:34pm
I got it apart. Tied one end to my grader and the other end to my kubota. Jerked it apart. Now to find seals for it.
