Only roto baler operators will understand
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Topic: Only roto baler operators will understand
    Posted: 21 Jun 2026 at 7:24pm
So, have you ever just been minding your own business, toward the end of june, with all your first cutting tucked safely in the barn when someone asks you for a favor to make 5 acres of hay for some old ladies sheep. And they promise you the field is really close and the hay was made last year or maybe the year before. And you drive the 10 miles up and down hills to get there(wow, i thought it was closer) and you look at the field full of broadleaf weeds and you know you should just turn and run. But for some reason you still don't understand, you agree to do it . And it takes you four hours to mow 5 acres because the field is full of ground hog holes. And so you tend it and rake it and its 4 pm and you have to milk but because it such nice drying weather you figure it can wait an extra day. But in spite of the low humidity, jt gets wet underneath overnight and now , if you flip those perfect windrows over, they will get too narrow and WE ALL KNOW HOW ROTO BALERS HATE NARROW WINDOWS. Plus the rake is going twist those corners into knots that will plug. And its not the great drying day like the weatherman forcasted, and you know those weeds are never going to get dry enough. But you struggle and get all baled. And the old lady comes out and says she doesn't want it only the second cutting and she has someone else to do that, he just didn't want the mess of first cutting
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 7:44pm
Yikes! OuchDeadThumbs Down
To borrow a quote:
You got to know when to hold'em, know when to fold'em, know when to walk away, and know when to run!
Edited by Les Kerf - 21 Jun 2026 at 7:50pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 9:10pm
That is why I only make hay for myself,but years ago my dad and I went all over the area making hay and baling with a Roto Baler for other people
Steve A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve A Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 7:06am
AAAAh...YEP! And about halfway through the upper roller pops off and you go get the jack....
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 9:49am
Hopefully, somewhere-somehow there will be a payback for your futile effort & wasted time.  Those are hours you'll never get back but you learned at least one thing and that came from trying to be the good guy.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 11:48am
My father did a lot of custom haying for farmers. He charged by the hour for cutting, kicking and raking (clock started when he left the farm), $X / bale for baling. They would tell us when to cut (he didn't want to be their weatherman!), and when to bale though we'd advise if the hay was dry enough to bale. They had free use of our hay wagons and their labor for the handling of bales.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 2:19pm
GOT a match???
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 3:24pm
GOT a match???
My thoughts, exactly...  Pile up in a giant F U and light it up!Angry
BobPaulusCentrOH View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobPaulusCentrOH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 6:02pm
Sorry about your luck.  Take heart, there is a special place in heaven for guys that are rewarded such as you were.  A bushhog is too good for a field like that.
Bob
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 7:06pm
The altruism is all well and good. There is an elder down the road who has a couple of old beef cows. It will only take an afternoon to get it picked up and he would appreciate it. I was kind of referring to the agravation of trying to run a rotobaler with the combination the rows too narrow and the hay too wet.
You know one thing about a roto baler, you can abuse it and it will give it right back, in spades!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2026 at 7:38am
No good deed goes unpunished!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2026 at 1:34pm
OK, so you tripped the memory trigger on round bales and I'm showing my age here.  Growing up in eastern NE as a teenager in the 50's & 60's I have round bale stories.  My Dad & his 2 brothers had 2 separate dairy operations going and round bales were the hay source.  As I recall, they all took good care of equipment and the problems with a round baler behind a WD were minimal.  The double windrow was the key, and you got pretty good with a rake doing those.  Where myself & my cousin come in we had to turn the bales 90 degrees so they would feed into the first loader they had.  Also, if the bales got rain on them in the field, we had to roll them wet side up for drying.  A later Allis loader did a good job of turning the bales so that job was eliminated.  Now, the real fun part was building stacks with round bales tying in the corners, so they didn't blow out.  Some hay went inside and the rest got stacked.  We would feed them by using a hay knife & slicing the bale in half while pulling the twine off.  Oh, the memories.
57WD45CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 57WD45CA Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2026 at 5:22pm
I too grew up around round bales.  The next door neighbor ( 1/4 mile away), partnered with Dad putting up alfalfa hay. I remember cutting, raking, baling, and hauling the bales. Dad would build a stack at the feed rack, making and stacking 2 rows for the outside perimeter and dumping the bales off the grain elevator into the middle, pulling more bales to the outside double rows to contain the loose bales. They always seemed to shed the rain and snow fairly well and were close to the feed rack for feeding.
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2026 at 7:15pm
I grew up with them and when everything is right, i can make a lot of hay. Not like a modern round baler but i can make a new holland 273 cry for its mother but if one thing is wrong, like the row too narrow, it will not fill the entire chamber and on discharge the upper end belts can catch under the frame. Also if the hay is not soft, like stuff that has woody weeds in it, loose strands of the weeds can catch under the discharge arm and prevent them from latching after it discharges a bale. And if the hay is wet or really long stands the baler will have an annoying habit of discharging the bale before its wrapped with twine. The most annoying part of baling with a rotobaler is an unwrapped bale. You can't easily rebale it, it won't go up a bale loader and its a mess on the wagon and it the mow
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2026 at 9:11pm
I was born in 66. My dad and uncle farmed together, dairy, cattle hogs, corn, soybeans and wheat. Lots of alfalfa, fescue hay and straw all baled with a D-17 and roto baler. I know we baled 15k bales a year until 85 when dad and my uncle went separate ways. We had a 13 x 8 trailer, 3 wide 3 layers 2 wide 2 layers and a single row across top. 103 bales if I remember correctly. That ol baler brings back some good memories.
Leon B Mo
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2026 at 10:36pm
I was picking up equipment after an auction once and bumped into one of the sons of the deceased seller. It was a pretty early one and had been outside for years, and scrap was high at the time, so it was expensive enough I didn't try to drag it home. The son told me they all called it the "Hail Mary Baler" because they never knew if it would spit out a bale. I still get a chuckle out of that.
You were awfully nice to bale that field.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2026 at 6:56am
I've been watching for a nice Roto-baler. Have been interested for years, now a buddy from the Meadow Green persuasion has shown interest. He has lots of acres of hay ground and a big building to store such things in. Maybe one of these days there will be Roto-baling video on  my channel? Once the 78 rake is 'done' it will likely go there for 'testing'.
