Name/Source for Bushings/Sleeve Bearings
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Topic: Name/Source for Bushings/Sleeve Bearings
    Posted: 20 Jun 2026 at 9:43am
I am running into a number of bushings/sleeve bearings on my older ACs that I haven't been able to find off the shelf equivalents for from SKF, McMaster-Carr, or wherever. Examples would be the CA steering gearbox bushings and rear lift rockshaft bushings. The ones I can find online for the ID I need have too thick of a wall, so the OD is too large to fit.
Am I searching for the wrong names? Is there some secret source for these still out there? Did Allis really use custom-made special thin-walled bushings in everything... that would seem odd to me?
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2026 at 2:29pm
The bushing/sleeve may have been made by, or for, AC to their spec.  Have you found any with the right OD, but a bit small on the ID?  Many bushings get reamed to the proper ID after they are installed, they often are not sized properly to work without that step being done.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 5:46am
Have you checked AGCO? You might be surprised.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 8:38am
I always check AGCO. $95 for one of the steering gearbox bushings (takes 2!) makes me want to check all other sources first!
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 9:07am
Most of them would be too small by 1/8-1/16" which seems like a lot to take off with a reamer, maybe?
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 9:32am
It could be done with a adjustable reamer in steps. If you know somebody with a lathe they could size them in a few minutes. Ive done it in a milling machine before i had a lathe just takes more time
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 9:35am
I made many of them. Soft jaws in lathe and turn the ID to proper fit. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 11:41am
The original bearings appear to be steel-backed bronze (or similar copper-based metal on the ID). They have pockets for lubrication retention. If they were designed to be reamed after installation, it couldn't have been much more than a touch up reaming.
Maybe they really were custom for AC/Ross/NH/IH etc.? Still seems odd to me that these thinner-wall bushings appeared to be so common in ag equipment back in the day, but are very difficult to find now. Due to the usage I just figured they had to be off the shelf items back in the day.
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 8:25pm
Look up 'DU' bushings (made by Garlock/GGB), or 'TH' bushings made by Daemar. Think that might be what you're after. Pretty common in the industrial world. Both companies make several similar types of bushings, but the DU or TH are the most common. The DU and TH bushings are interchangeable - just different names for those offered by different companies.
Edited by DanielW - 21 Jun 2026 at 8:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 8:57pm
I think McMaster Carr has sintered bronze bushing stock, comes in a 13" blank, choose size and cut out your bushing on a lathe...Wink
Just checked, they have both rods and tubes, you just need to know the ID and OD. Search sintered bronze bearing stock.  Longest they now stock seems to be 6-1/2" long...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 10:41pm
I doubt anything but steel backed bronze with all those little pockets would hold up on the rock shaft area of a WD. A bronze sleeve would be pretty thin in that area and probably squish out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2026 at 11:29pm
The DU and TH bearings I mentioned above are exactly that: Hardened steel outer shell with a porous bronze/ploymer I.D. with pockets for lube entrapment. And very thin wall. Meant for very high loading - much higher PV-rating than your typical 660 bronze bushings. I strongly suspect that's what Allis used - DU bushings have been around for ages. Never had a WD/CA apart to know for sure, but I know they're very popular in the industrial world, and I know both my old IH haybine and Fordson steering arm used them.
Edited by DanielW - 21 Jun 2026 at 11:36pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 7:58am
For just a bushing look into neopreme bushings.On the concrete block machine I used to run and work on the Besser company replaced the brass and steel bushings with neopreme bushings and they would out last either steel or brass,Cheap and buy the outside diameter you need and drill to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 6:43pm
Thanks! That was very helpful. Unfortunately, even with those, neither appear to offer a 1.25 bore bushing with 1.375 OD, as one example... They are 1.406 (1 13/32) OD. Which maybe tells me things have just shifted over time and what used to be a common off the shelf size used by at least several equipment manufacturers went out of style for some reason. I supposed I could turn those down a bit if I get a lathe (which I do need to do).
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 6:44pm
Yes, this would be my concern even if I could make something out of bronze stock-type material. I think that steel backing with the thin layer of bronze is probably necessary to last very long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 7:37pm
Interesting. I would have bet dollars to buttons that's what they used, but I guess not. If you're having some made, consider C954. It's a pretty popular material to make custom bushings from in the industrial world. It's an aluminum-bronze alloy - not your basic bronze. Much higher load/PV capacity than regular bronze.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 9:48pm
As far as bronze bushings holding up under weight, on a Besser Block machine with bronze bushings on a 6 inch diameter shaft and between the weight of the shaft and the mechanicism it lifts and lowers every 9 seconds easily weighed more than a WD tractor.they would hold up a long time making several million concrete block a year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2026 at 11:43pm
932 or 954 aluminun bronze will be fine. Better than what come in it. The steel backed bushings are sintered metal, we made them at my first job. It is soft enough to be formed and not break. I personally make most of mine out of 932 or the tough stuff, 954. HTH, Tracy.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2026 at 5:48am
I'm not doubting what you said, but that amazes me. Who says you can't teach an old man anything?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2026 at 6:54am
The thing with bushings is they need to be made out of something that will wear down and not wear down the shaft.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2026 at 1:19am
Pretty sure the rockshaft bushings that you are looking for are these: https://awtractor.com/product/225815v-lift-arm-shaft-bushing/
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:28pm
Thanks. I think the "best" thing to do for the rockshaft bushings is probably to bore the mounts out to that slightly large diameter so they'd accept off the shelf bushings DU etc. these days. That would also take care of the ones you tear into and find out the rockshaft wore through the bushing decades ago, and now the bore of the casting is oversized/out of round. I think there is enough meat there on the CA and WD mounts to make that work? Of course I do not have enough machining equipment yet to make that happen on my own.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:31pm
Thank you! I will keep those materials in mind when I get some machining equipment. That is the goal someday... Even a little Atlas/Craftsman lathe would be handy for smaller stuff like that. I've been keeping my eye out for one to start with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:42pm
It would be interesting to know what the pressure on that was compared to a WD rockshaft. That is a lot of bearing area compared to the rockshaft bushings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2026 at 6:51pm
Yep, those would be the CA ones. You're out of stock though!
