1947 WC Allis Chalmers - Sediment Bowl Gasket Leak
Mkiester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mkiester Quote  Post ReplyReply Direct Link To This Post Topic: 1947 WC Allis Chalmers - Sediment Bowl Gasket Leak
    Posted: 05 Jun 2026 at 7:36pm
Hello,
We have a 1947 WC Allis Chalmers.  I recently replaced the sediment bowl gasket with a new cork gasket, and I am unable to get this seal (there is gas that still wicks out from between the top of the bowl and the gasket).  I have tightened the nut under the bowl about a far as I dare as I am concerned with cracking the bowl.  Does anyone have any ideas why this still leaks?  I think that the valve packing is ok.
Any help that you can provide would be greatly appreciated.
Chuck and Mike
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2026 at 7:41pm
The most common problem that causes the leak you describe is distortion of the body of the sediment bowl due to over tightening of the nut over time.  Usually best to replace the sediment bowl as it is next to impossible to straighten the body to get a flat surface where the gasket seats.  I've replaced quite a few over the years due to this problem.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2026 at 8:52pm
Before anything, make sure the leak is not coming from the valve or where the sediment bowl threads in to the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2026 at 10:00pm
If the cork material is brittle you will not get a good seal. It has to be able to compress.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 2:57am
2 things, it is likely the pot metal rim/bail clip distortion, as mentioned above. A double thick cork gasket and a dime between the nut and glass bowl may work for a while, but sounds like you need the whole bowl assembly...Wink
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 12:46pm
where the gasket goes aint clean enought scrape it real good with a flat bade screwdriver til it shines
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2026 at 12:47pm
Try turning the bowl when just snug, it seems to seat the gasket and bowl and then tighten more.  May need to do it more than once.
