B underhood muffler
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: B underhood muffler
    Posted: 24 May 2026 at 1:52pm
Would it hurt anything if I were to add a 20” piece of pipe to the exhaust to keep the fumes out of my face?
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2026 at 1:55pm
no... extension would be OK...
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2026 at 9:42pm
It is very difficult to add an above pipe extension to an under hood muffle, because of the odd shape and angle of the pipe, If you want an above hood pipe why not get an above hood muffler and get the heat above the under hood area. The reason for the under hood muffler is to clear trees and branches, like when using a cutter bar.  Cal in Ct
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2026 at 10:30pm
So I have actually been wondering about this. The CA manuals/parts books show the under-hood muffler as part of the low compression, low octane intake/exhaust equipment, with the high compression gasoline equipment having the above-hood muffler.
Did keeping the muffler under the hood help warm the distillate/low octane fuel in the intake more than an above-hood muffler would? Otherwise, I can't figure out why it was tied only to the low-compression option. I haven't looked back at the B parts catalog yet to see if it had a similar relation.
I know the OP was asking in another thread about converting his carburetor to gasoline parts. If you want to do that, and assuming you are only running on gasoline these days, that might also be another reason to change to an above-hood muffler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2026 at 10:32pm
Whoops - mixing up my Johns! I can't edit my post above due to the 404 error I get in the text editor. Sorry, not the same guy that was asking about B carb parts!
Either way, I'm curious about the reason for the underhood muffler with the low octane equipment group.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 6:00am
It had the underhood when I bought the tractor.
Wasn’t hard, I smashed the pipe to fit the muffler.
I read somewhere that the underhood was to keep water out of the manifold. Since the muffler goes in side the manifold, rain water would get into the manifold.
'41 Allis B
'49 Farmall Cub
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 8:21am
Did keeping the muffler under the hood help warm the distillate/low octane fuel in the intake more than an above-hood muffler would? Otherwise, I can't figure out why it was tied only to the low-compression option...
That is an interesting question, I installed an underhood muffler on a Model C 30+ years ago and it most definitely added a significant amount of heat. I was happy to get rid of it Angry
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2026 at 9:12am
It is easy enough to round out the underhood muffler to allow an extension to slip on. That is what I have done on my RC.
Just use a large punch to start swelling it round again and follow with larger pieces of round stock.
