D17 distributor
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Topic: D17 distributor
    Posted: 21 May 2026 at 7:46am
Is a D14 and D17 ditridutor the same. My D17 quit firing all if a sudden and ive got a pertronics distributor in aD14 that the engine is no good. Wondering if i can swap them
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2026 at 8:39am
Parts book shows to be all the same part # as with the drive gear. I would have said no but the parts book would have proved me wrong. Guess they designed the engine around the distributor dimensions ! Go for it.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2026 at 9:35am
Originally posted by tbran tbran wrote:
.... Guess they designed the engine around the distributor dimensions...
That was, of course, the sensible thing to do; therefore it is amazing that the design engineers chose that path! TongueWinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2026 at 9:49am
One notable thing between the two engines is/was rated speed was 1650 RPM and the high idle speed was 1950-2000 RPM. So, the advance mechanism should have been the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2026 at 10:12am
Great. Thank you. Itll save me a few dollars
1984 80780
1957 D14
616 tractor
This page was generated in 0.097 seconds.
