allis chalmer 160
flem1951 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote flem1951 Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmer 160
    Posted: 17 May 2026 at 11:24am
greetings,
my three point will not stay steady, it drops and wont remain stable a any given point.
any suggestions would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2026 at 10:27pm
Need some info from you. Check the fluid level? How long has it been since the hydraulic filter and fluid have been changed? Are you using a good quality 821XL fluid? Have you cleaned the hydraulic filter to the right of seat and replaced the hydraulic fluid filter at the front of the tractor? All of these can cause the issue that you are having plus air in the system. Also check the hose coupler for the suction line going to the pump, it’s located near the bell housing on the right side of the tractor as you set in the seat. It has 2 clamps and they must be tight and the coupler hose needs to be in good condition so it can’t suck air into the system. Also keep the traction booster lever pulled to the rear, inside lever beside the 3 pt lifting lever.
