$5 diesel fuel usage
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: $5 diesel fuel usage
    Posted: 18 Apr 2026 at 7:39am
Farmers running 500hp 4wds doing spring tillage are probably burning 20 gallon/hr @$5/gal ~ $100/hr per that one tractor? So during long hour spring days (16-18hr+) that could become $1600-1800 / day fuel cost per that one tractor?
If that 4wd is pulling a 50’ FC @ 7mph, in theory without headland turn time factored, that becomes 42.4 acres / hr per $100 of fuel. Or, $2.36/acre fuel usage. If in reality, 10% of travel was utilized for turning, then fuel usage is probably closer to $2.62/acre? That’s factoring a square 40 acre field ( 1300’, minus 50’ headlands(1200’ passes?) considering a constant soil pull load on FC, which is probably seldom the case?
Same could be applied to semi tractor trailer rigs moving goods up & down our roadways.
Most 80k loaded semis could be averaging 5-6 mpg (11-13 gal/hr x $5/g ~ $55-65/hr) ?? Some lighter freight semis may average a little higher 7-9mpg (7-9gal/hr x $5/gal ~ $35-45/hr) ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2026 at 8:32am
Is starting to turn lower.  At least here, avg is around $4-$4.40 and coming down a little at a time.  HOWEVER, as many I speak to here note, when already cutting close as to break even of Corn or Beans or Wheat, a few are not bothering to plant.  NOT taking loans to buy materials or get on lists for Fertilizers or Seed.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2026 at 7:43pm
Well, that's if you're buying road deisel from the pump. Which BTW was $4.96 at one station today. Though others were still $5.19. Certainly, many are buying ag fuel which doesn't have all the road use taxes added? As an example, I paid $3.69 for ag fuel but that was before Iran got bombed. Pump price was more than that at the time
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2026 at 8:22pm
Fuel per acre is peanuts compared to fertilizer per acre, which is NOT going down.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 6:51am
The gallons per acre, for the most part doesn’t change a whole lot per the job being done. The big variable is acres per hour, this is achieved greatly by the size and configuration of equipment being used.
