Any information on input Hd-5
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Topic: Any information on input Hd-5
    Posted: 12 Apr 2026 at 12:56pm
Any insight or information on changing the seal, gasket. on the input shaft to transmission of HD-5.
1951 Model
Thanks for looking and your response.
Thank you
Les Kerf View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 3:50pm
I have yet to replace the input shaft seal on an HD5 but I did extensive re-work on the shifter, and I can state that just checking the oil in the transmission would be easier if I were a trapeze artist.
Best wishes on your project Big smile
gemdozer View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 4:26pm
You need to removed the drive shaft and removed the input shaft yoke and pull the gasket seal,2ring seal and boot assambly
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 5:13pm
Thanks for your response to question.
I had the fuel tank off of the tractor, so it was easy to fill the transmission with oil.
When I had reinstalled the fuel tank and finish putting everything back in place. I notice oil leak around the input shaft.
 Would it be possible to replace the seals without removing the whole transmission?
Are replacement parts easy to find, by using HD-5 parts number?
Thank you
Post Options Post Options   Thanks (1) Thanks(1)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 7:29pm
The transmission use 5 gallons oil inside and it should be lower the input shaft and the seals can be change with out removing the transmission and am still have these seals and if your transmission is over fill you need to drain some oil and it should have a small plug under case and oil should be gear oil 50  or 80\90
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 8:07pm
Gemdozer
Yes, I'll check oil lever in the morning.
If you have the parts for input shaft seals, please sent a price and part numbers.
Or I can send a parts list that I have.
If you would like, you could PM me.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2026 at 8:19pm
Oil fill is on top of transmission , level plug to check is on side (1'4" pipe plug)
Seal is 2 parts - a brass seal disc mounted to yoke and another to transmission , to hold pressure on these 2 plates is a boot seal - a spring assembly enclosed in a rubber boot which is said to be held onto 2 parts with contact cement .
 Seal is the 2 discs which have a set of lines cut into them that spiral oil back into transmission when turning - setting still the face of seal just fit close tolerances to prevent oil seepage .
 As oil in transmission also serves the ring and pinion case and side bearings , level is important .
Edited by Coke-in-MN - 12 Apr 2026 at 8:21pm
Ray54 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2026 at 11:56am
I have never had the seal on the input shaft leak. I have replaced several of the rubber boots that go on the rod that locks the gears in place when the clutch is engaged.
When hunting for better shifter linkage parts, had a person that rebuilt lots of the crawler transmissions tell me to replace the top shaft front bearing.  If that bearing goes out it drops the ball bearings into the gears. As well as damaging gears it can break the case. It was not hard to do. And not many years latter I had a lower bearing go.
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2026 at 5:40pm
This for Gemdozer
Items #       Parts # for input shaft
#55-049110  ring seal input
#56-056589  ring seal
#57-049836  gasket
#58-056588  spring assembly Not if needed
#59-082795  boot
Thank you
Not sure if this PM message or not
BFC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BFC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2026 at 11:30am
I would like to thank everyone for the information that gain by posting a question on this site.
Corky
