Ih exhaust manifold spasers for 426
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Topic: Ih exhaust manifold spasers for 426
    Posted: 22 Feb 2026 at 9:33am
I read a post years ago on putting 400 series IH exhaust manifold on 426 engine. My original series one manifold is shot on my D21 puller and would like to find who made adapters for the IH manifold. Could not find that old post. Any ideas? Doyle Bounds Missouri Mule D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2026 at 1:19pm
Probably was me. I made them for my D-21 that I had some 30 years ago. With a Bosch "A" pump I was able to spin an Air Research TO-8 turbo.  I made them out of 1 inch thick steel blocks. The holes that attached to the 426 cylinder head were countersunk and used short 1/2" NC Allen head bolts. The DT-400 series manifold bolt holes were top and bottom so the blocks were thick enough to be threaded and hold the IH manifold up against them. It was very time consuming to make, as the IH manifold is only two pieces, instead of three like the A-C manifold. So you fudge a little bit on how you make the spacers. The A-C ports are rectangle while the IH are square, so you spend a lot of time with a die grinder blending the spacers to fit each port. It was all worth it, but will try your patience getting it done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2026 at 4:33pm
DrAllis: Would you mind talking to me about spacers? Is your number (319)360-4788 ?
if so when would be a good time for me to call. Doyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2026 at 7:09pm
Nice talking to you again, Doyle. Good luck on the exhaust manifold update.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2026 at 6:39am
Doc, if you charged us all for your advice, you would be a millionaire!
Thank you for all you do for all of us!!!
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 5:39pm
Here’s an option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 8:14pm
The reason the IH-400 series manifold is superior to the A-C original manifold is because the exhaust gases basically take one turn out of the cylinder head port and then head down the tight sized runners. The tight runners keep the exhaust gases from expanding until they hit the turbo exhaust wheel, which is more efficient. The manifold is also designed for the "pulse" effect by splitting 1-2-3 and 4-5-6 to separate runners. This manifold pictured still takes two turns for the exhaust gases and the runners look to be large which slows down the exhaust gases speed. It is split ports at the turbo mount but that's about it.
