AC 816 Steering Orbital
Norris1606 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norris1606 Quote  Post ReplyReply Direct Link To This Post Topic: AC 816 Steering Orbital
    Posted: 03 Dec 2025 at 10:37am
Trying to find info on the steering orbital for this 816 backhoe I recently purchased.  I'm sure it was used in other applications, but the tag is gone off the orbital and the part number in the book has gotten me nowhere.  Do anyone have any info as far as manufacturer or a number from the orbital itself or even if there is a known interchange?  Thanks in advance!
Sids View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sids Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 12:34pm
Can you post a picture? It is most likely a common valve. What is wrong with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norris1606 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 9:23am
I try to brave the cold later today and snap a couple pictures.  It looks like just about every single one i see on the interwebs, I'm just not sure about internal compatibility.  I has a crack in the case and is leaking a steady stream of fluid.  Before the weather turned cold, I took it apart and the crack in the case goes all the way through to the internal passages, so I figure a replacement is in order.
