D 15 series I Industrial 14.9X24 rim
fglass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fglass Quote  Post ReplyReply Direct Link To This Post Topic: D 15 series I Industrial 14.9X24 rim
    Posted: 18 Nov 2025 at 12:32pm
Looking for a compatible rear fixed  rim 6 hole, 8" across the farthest bolt holes, with a 6" hole in the center.  rim edges are 12" across in width.
Thanks for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote fglass Quote  Post ReplyReply Direct Link To This Post Posted: 19 Nov 2025 at 4:09pm
CORRECTION ON NUMBER OF HOLES: IT IS Eight (8) Lug holes and 8" across the farthest holes..
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 2:03pm
What are combine rims?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2025 at 2:06pm
Generally a standard combine rim will not have as thick center as the Industrial tractor will have. However if you look around enough it is possible to find a heavy duty center on a combine rim. Also most combine rims are 26" the original post is looking for a 24" rim.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 27 Nov 2025 at 11:26am
