Fuel line for Ac 175d with Perkins 248
sageeyah175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sageeyah175 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel line for Ac 175d with Perkins 248
    Posted: 16 Nov 2025 at 11:46am
Hello to every one, been a while since I asked for some help, I have a AC 175D, replacing the fuel transfer pump and the fuel line from pump discharge to filter canister is leaking. Did a parts lookup, part number 70257404, might not be  available . If you know of any salvage yard  that might have one I would be very thankful. Thank you.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Nov 2025 at 2:45pm
Get some small diameter tubing from Napa - I prefer the straight lengths - can't remember the diameter.  Then use tube benders to shape it from point A to point B.  That's what I did with mine.  Pretty cheap fix, just takes a bit of time to get the bends right.
