Part Number for 1971 HD11E Starter, AC 11000 Eng.
bulletpruf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulletpruf Quote  Post ReplyReply Direct Link To This Post Topic: Part Number for 1971 HD11E Starter, AC 11000 Eng.
    Posted: 03 Nov 2025 at 8:07am
I don't have a parts manual handy; would anyone happen to have a part number for a 24V starter for an HD11E?
Thanks,
Scott
Edited by bulletpruf - 03 Nov 2025 at 8:07am
Please check out my YouTube channel at: https://www.youtube.com/@THEBULLETPROOFGARAGE
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 9:10am
Is a Basic 40MT Delco, or should be, just in 24v 11t bendix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulletpruf Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2025 at 9:12am
Thanks!
Scott
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 4:01am
From experience with an AC Forty Five grader  an M 42 with the right pinion will work
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 11:20am
From discussion in other places 40 MT is the old model no longer supported, or at least very poorly supported. The model 42 MT is current and a direct replacement. But placement of solenoid and nose cone and direction of power all need to specific for your application.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2025 at 12:04pm
Nose cone on any of the later starters is irrelevant, all are mounted with Six or Five Allen Screws and are repositionable as needed.  Is ONE slight Offset on the Basic Front Motor Housing, one has No Offset to Solenoid the other is one half hole distance off that.  Regardless, the Current style is not even a 42MT but a Gear Reducted 1/3 size to these old monsters 39MT.  ANY HD Truck parts outfit will have.
Available 12 or 24v
Post Options Post Options   Thanks (0) Thanks(0)   Quote bulletpruf Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2025 at 7:39am
Thanks for the input.
