All Crop grain drill
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: All Crop grain drill
    Posted: 31 Oct 2025 at 8:40am
Needing repairs for 18 hole All Crop grain drill - specifically, 2 seed cases. that is what meters the seed into the seed tube and then in to the ground. Previous owner apparently used screw driver or chisel to remove degree and punctured case. Thanks
Simon2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Simon2 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2025 at 7:07pm
Assume these housings where same on all drills ?   Have a mounted parts drill, will check condition
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 6:32am
I am also assuming they are all the same?? I need to replace 2 of them if you have. Thanks
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2025 at 6:46am
There is a couple different opener housings. Better post a picture
Edited by im4racin - 02 Nov 2025 at 6:47am
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2025 at 5:28pm
According to my All Crop drill parts book, there are some superseded numbers but no change in seed case. The most recent part number is 339944. Does anyone have 1 or 2 of these? I would take picture but drill isn't here and I can't download anyhow. Thanks
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2025 at 6:00am
Are you talking about the part that the square shaft runs through?
Edited by Lon(MN) - 11 Nov 2025 at 6:01am
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2025 at 7:21am
Yes sir! That part meters the seed that goes down thru seed tube and into the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2025 at 5:56am
I have some of those, but all my tractor stuff is on hold until I get my house done and moved in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Simon2 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2025 at 8:30pm
Sending you PM on drill seed
Parts
