hd11e steer clutch questions
butch1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Topic: hd11e steer clutch questions
    Posted: 24 Aug 2025 at 8:55pm
Hello all, has anyone used the steer clutch springs from general gear? I got my order of disks and springs Friday the replacements look like die springs the pressure checks @ 220lbs aprox on the springs but the 62 year oem rusty ones checked 250 to 285 @3 11/6 inch, oem spec shows 235 to 265 thats only 66% im concerned any input would be appreciated. the unit is a 62 or 63  hd11e.
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2025 at 9:01pm
sorry specs show 335to365 lbs
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 11:54am
In general General Gear gets good reviews. But If you have specs for springs and a way to test them it make sense to check. No matter how hard one tries most stuff comes from China.
I had a new to me 1950's  Cat D6. Steering fine until it was not. Pull one steering clutch and you stopped. I want to say springs were less than 1/2 of spec.  But my tester was not the greatest. Set a bathroom scale in my hydraulic press, pressed spring to what ever the length for spec was. Read what the bathroom scale read.
Tad Wicks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 11:56am
That is certainly a substantial difference. I bought new ones at Fresno Tractor years back, might be worth a try.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 1:56pm
I am still have some stering cluch springs and I check this morning some spring wire are   thin and some are complet round and need more pression
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 6:14pm
yes i did test them used a short stroke hydraulic cyl 2 inch bore filled with oil and a pressure gauge installed in the port and the quil on my cnc mill to push the spring down on the rod to checking height 3 11/16 inch then used a hydraulic force calculator from baum hydraulic to psi to calculate 335 and 365 psi  365 =115 at gauge reading i think 106 was 335# i checked 4 new springs 2 were 60#,1 was 65 and 1 was 72#.Next i stood on the end of the cyl and balanced on it it come out to me weighing 220 lbs, the bathroom scales showed 223 lbs so i feel its a solid test. i have some pics in my phone of fixture and readings i will try and post. I called general gear they seemed like good people i'm probably going to send them back , i do feel the were probably imported parts. The thing that sucks i work as a maint mech in a 2,000,000  square foot caterpillar facility in morton il and its not a d6Cry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 7:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 7:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 7:15pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2025 at 8:23pm
All I can say is your numbers check out correctly on my calculator; it certainly appears that you have weak springs Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tad Wicks Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 11:25am
Like Les said your numbers are correct, 2 inch bore is 3.14159 sq in, so simply multiply your pressure reading by 3.14159. Those springs don't look like the ones I have, mine are   round stock like the old ones you show. When I rebuilt my clutches the springs in one side were broke to hell. it looked as though somebody stacked round stock lock washers where springs used to be, they were all broke into 1 coil turn each. I still don't understand that.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 4:47pm
ok im going to take a stab in the dark here; mainly as HD11 books aren,t where i am.
BUT is your HD11E a wet backend one ??  Wet backend clutch springs are alot stronger than the standard dry backend steering clutch springs; which is probably what general gear supplied you with. . ?
Part numbers from the right books will tell the storys !
tits tyres and tracks
they all cost you money
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 5:29pm
The wet stering cluch spring are 6 inch  and dry are 5 inch
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 7:30pm
no the replacements were a die spring type we use a few around the plant on vertical conveyors. ok here's the  deal on the dozer i bought it broken a couple months ago with a broken bevel gear shaft. Someone local was parting out a hd11e serial number 12000 and change my hd11e is 7464 dry clutches and hydraulicly boosted steering and wet clutch trans. Misreading the manuals i went down and removed all the clutches, brake drums, bands, and bevel gear and shaft and blade cylinders there are a lot of differences in the machines steer clutches the way they are acuated the bevel gear is the same the shaft is .340 wider from brgs out and brake drums are .340 narrower.my pinion and bevel gear were worn a little mostly the bevel gear i used the bevel gear and shaft set the bearing preload per the manual and the backlash by moving the side shims came out at.007 backlash spec is .008to.014. then i decided to make up for the extra shaft length be making new yoke buttons from drill rod and heat treated then hardened to about 60 rockwell c scale a file is 65. Everything looks good so i ordered clutches, brake linings, and springs. Between me and my son we want to build ponds it prabably wont need to run 100 to 150 hours i only have 5000 in it and parts. So if it breaks i can at least scrap it, and yes the wet springs are longer and pressure is like 750 lbs i think it has to be higher because 50% less surface area from grooves in the frictions and oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 7:45pm
I decided to try and cutdown the wet springs heat and fold the tails regrind the bases the picked 8 wet springs and 8 dry springs alternated them 4 in a cross on each hub my total calculated pressure from all 8 springs are in the 3750lb range at 3 11/16 but the wet springs build pressure quicker when compressed farther so i hope it works i will let you know how it turns out figured i had the parts and they were not really good so i might as well try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote butch1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 7:54pm
gem dozer do you have a hd11 under 10001 serial number that still has its bevel shaft if this doesn't work out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2025 at 8:06pm
I am gone to check tomorrow and comback you
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2025 at 4:41pm
I have a HD11  bevelgear shaft and part number on is 056777
